What is a CO Resistor?
mx4life
Post by mx4life »
I pulled some codes today from my car . CEL code 49. Says it's CO Resistor. Any ideas?
Click For My 93
Click For My RHD 97
'93 SS V3 RA/STi EJ20K 4.44 DCCD
'97 RHD Wagon soon to be TT
BSOD2600
Re: What is a CO Resistor?
Post by BSOD2600 »
Where are you reading it's a CO resistor? http://legacycentral.org/library/literature/codes.htm says its the MAF.
'11 WRX Limited
'94 TW | R.I.P.
mx4life
Post by mx4life »
Click For My 93
Click For My RHD 97
gijonas
Post by gijonas »
those look like OBD2 codes,not what you want to go by for your car.
mx4life
Post by mx4life »
it said they were obd I, I dont know. I have an active 32 code and thats O2 sensor. Are the O2 wide band or short band? Can I buy the 2.2's and get away with that?
Click For My 93
Click For My RHD 97
BSOD2600
Post by BSOD2600 »
The o2 is narrow. What modern car comes stock with a wideband o2?
'11 WRX Limited
'94 TW | R.I.P.
mx4life
Post by mx4life »
I dont know if any cars come stock with wide, I used to build drag cars so I was askin. I found a forum where people are talking about the CO Resistor but its in spanish.
Click For My 93
Click For My RHD 97
Those codes are not applicable to your legacy. Use the ones posted by BSOD2600
mx4life
Post by mx4life »
Ok, I replaced O2 sensor. Now I have another problem. After I cleared the codes the car runs worse and it's coding coolant temp sensor WTF? I have no idea why.
Click For My 93
Click For My RHD 97
BSOD2600
Post by BSOD2600 »
Check it per the FSM specifications. The manual is posted in the stuff you need to know forum....
'11 WRX Limited
'94 TW | R.I.P.
IronMonkeyL255
Post by IronMonkeyL255 »
I believe the new turbo beetles and maybe some of the other turbo VWs used a wideband from the factory. I seem to remember a wideband kit that used the sensor off a beetle......
Rio Red '91 Legacy SS
BSOD2600
Post by BSOD2600 »
IronMonkeyL255 wrote:I believe the new turbo beetles and maybe some of the other turbo VWs used a wideband from the factory.
Ah, so you're correct -- turbo VW's though ;).
According to this post, some vw, audi, bwm, and gm's use them.
'11 WRX Limited
'94 TW | R.I.P.
