ecu
RS2ENvY
ecu
Post by RS2ENvY »
Hi to every one just wondering, i have are subaru legacy 1994 rs and has had are single turbo conversion ,upgraded turbo,manifold,intercooler etc but my ecu is still factory and just had it tricked to run single but its cutting out randomly??just wondering what sti version ecu would fit??i was told are version 3 sti would fit but just woundering if are version 1 would do the same??any help? thanks
Re: ecu
Welcome to the BBS.
Where are you located? 1994 was the new model year overseas with the second gen legacy, and it would be helpful in determining suggestions for a new ECU.
RS2ENvY
Re: ecu
Post by RS2ENvY »
hi there im located in new zealand , just wondedring if are version 1 wrx ecu will run my single turbo setup properly??
Re: ecu
I would think it would likely work, however I'm not sure if the ECU connectors are the same.
You may want to ask over on http://www.rslibertyclub.org/forums
