turbo head gasket compressed thickness?
logan9691
Post by logan9691 »
I am wondering what the thickness of the turbo (stock not cometic) head gasket is when compressed. I did some searching and one said .059 and someone else said .065, but I need to know which it is.
Thanks.
Logan
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: turbo head gasket compressed thickness?
I don't know if I'd rely on my thickness measurement of .065". Due to the fact I used a non-subaru head torquing method when I put the heads on, not sure if my gasket thickness would be the same thickness.
