i found this in a box from the previous owner...
Subiel94
Post by Subiel94 »
so i found this in a box that the previous owner gave me... i know its a bypass valve... but um im pretty sure my car needs it but im not to sure. i think they removed it when the tmic was installed please help me and tell me if i need it and if so where do i connect it...?
BSOD2600
Re: i found this in a box from the previous owner...
Post by BSOD2600 »
Do you have a BOV or BPV on your car now?
'11 WRX Limited
'94 TW | R.I.P.
Subiel94
Post by Subiel94 »
I have a bov.
The BPV and BOV pretty much do the same thing.
Subiel94
Post by Subiel94 »
alright i was kinda worried like they set it up wrong. but thanks. still learning about my turbo legacy. :)
beanis05
Post by beanis05 »
a BPV is a By Pass Valve
a BOV is a Blow Off Valve
they are the same thing no need to worry, and if you have a topmount intercooler you should have one installed on it but I cant tell without actually seeing it
1990 Subaru Legacy L 89k auto to 5 speed winter daily driver
2004 Subaru WRX 80k
1988 Mazda Rx7 vert > Turbo 2 trans swap
1993 Honda Civic Vx Gutted
Subiel94
Post by Subiel94 »
Yup I got an hks bov I love it. I just wasnt positively sure. I'm new to turbo cars. But im really liking them. Haha
Mattheww044
Post by Mattheww044 »
As far as my knowledge goes you need one or the other... There are several debates on here on whether a BOV is "ok" to use over a BPV. The BPV recirculates the air back into the intake, where the BOV just releases it into the air. The ECU thinking that the air is coming back into the intake, but it not being there can cause some small issues that others don't want to mess with. I tried a BOV on mine and it idled like crap and didnt run quite the same, but of COURSE it sounded Bad-A :D
I'm just running the stock BPV for now
