1997 outback AWD tranny into 1990 legacy?
rally370
Post by rally370 »
I'm planning on buying a 97 outback AWD 5 speed this weekend. I'm told it will fit my 1990 cable clutch Legacy. Just checking this is the case before I buy.
Cheers
Chris
Rally Legacy AWD #370 gone! Rally Suzuki swift GTI N1 #370 parted out. Now Mini Cooper #370 with STI suspension in Costa Rica
Re: 1997 outback AWD tranny into 1990 legacy?
It'll bolt up. That thing should be a hydraulic tranny, so to keep your cable clutch, you move the clutch fork's pivot pin (in the tranny bellhousing) to the other bolt hole right in the area. You keep your current flywheel, clutch disc, pressure plate, clutch fork, etc.
rally370
Post by rally370 »
cool thanks. The seller says he had it in a 92 legacy so we should be fine.
Cheers
Chris
wtdash
Post by wtdash »
No offense to Mike, and I'm not the expert, but the '97 is a Push-style, hydraulic and the '90 may be a Pull-style cable, so I thought the clutch/PP/FW would need to match the '97.
I thought the pedal box was also different....I sold a turbo hydraulic pedal box a few years back to someone swapping from a cable setup.
Here's a POST w/similar info.
So, it'll work, but you may need to do some extra stuff.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Post by entirelyturbo »
Push- or pull-style refers to what the throwout bearing does to the pressure plate, not how the force is applied to the fork.
So, as long as they're both N/A transmissions, they should both be push-style.
Sent from my HTC Droid Incredible using Tapatalk
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
fishbone79
Post by fishbone79 »
I'm the guy who ran it. It worked great for 6 years, but I had started doing allot of field work with significant highway driving - I got tired of the low fifth gear so I swapped the trans out.
It was a direct swap, nearly identical to the first gen. In practice, 5th was really not that much lower than the others, but I had rebuilt a first-gen with higher 5th anyway.
Cheers,
morgan
1992 Legacy BF
rally370
Post by rally370 »
I got the tranny in other Easter break. The cutch was on the way out so I fitted a 98-01 Impreza RS ACT 6 pad race clutch which works great apart from in heavy traffic. The tranny is from a 97 outback and has a super set of ratio's the 5th is lower but all the other gears seem closer which really suits my 2.5/2.2 set up. Stripping down the old tranny revealed a broken sector fork so I was amazed I got the gears. One thing I always fit is the throw out bearing sheaf. This is a stainless steel construction fitting over the aluminium original surface. The clutch feeling with the cable clutch is super smooth and saves un-even pressure plate wear. I also fixed the oil leak as mentioned in another thread. Next to fix is the whinning rear wheel bearings.
http://i.imgur.com/vu0j0.jpg
Cheers
Chris
