what heads are using
Falken-18c
i was just woundering what heads ppl are using because i plan on geting a set later i was thinking of 2.5 heads off a legacy gt idk if they will work and also where would i find a set either post an add looking are go to a salvage yard
Re: what heads are using
I'm gonna be running v3 20k sti heads. I got a set of 25d dohc heads too i can sell. But shipping would cost a lot i bet. Also, i think Mike-Tracy has a set of 20g heads. Very good heads as well.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
im using twin turbo heads
Falken-18c
i can find the twin turbo engine lke 700$ i could use te heads off them is there any other parts off of it can i usecj91legss wrote:im using twin turbo heads
you can use the intake manifold too, possibly the throttle body. you'll definately want the 440 injectors that come with them and fuel rails.
you will most likely have to make some bracket to mount the coilpack like i did. or find an ej20k manifold, or ej25d (96 LEGACY GT) there's alot of stuff usable off the twin turbo blocks.
when i bought my twin turbo motor from jake, i resold the twin turbo setup to someone on nasioc for 75 bucks.
Falken-18c
what size of turbo on them are they bigger then td04 could i use 1 if so
bmxkelowna
no both turbos are quite small.
i have 25d heads and the intake manifold
