what Struts will fit?
ej22tVermont
Post by ej22tVermont »
I have a 94 legacy ss, that needs the front struts replaced asap. The question is that none of the parts stores can get me the parts in my time frame, but have struts for most any other model. Will any of the other model Subarus be a direct replacement, with no modifications needed? Any help would be great, this is a daily driven car that needs to be back in action within 2 days!
Falken-18c
Re: what Struts will fit?
Post by Falken-18c »
my friend has 03 or 04 sti struts in his 94 ss i think they just bolt in i hoping to get a set of sti struts this weekend
Falken-18c
are maybe they all work. and all you have to do is change the tophats i dont know. take a look in suspension i think theres a thread for what works and what wont.
What sort of time frame do you need to have these struts replaced?
The GC Impreza struts 93-01 should be very close to identical physical fit. The main difference would likely be in the damping rates.
ej22tVermont
So I randomly found a guy in the area with the one strut that was completly busted on mine, from the same type of car (SS). However this is just a quick fix for now. Now that I have bought some time I am looking to replace the entire set at once with new. Thanks for the info though guys.
