Power steering help
logan9691
Power steering help
Post by logan9691 »
I don't know what section you want this in. But I need some info on power steering lines. Are the NA legacy power steering lines the same as the Turbo power steering lines? Need to replace mine but the dealer price is outrageous and NAPA only has NA lines listed, but price is much more reasonable.
Thanks for the help, and move this to which ever spot it belongs.
- Logan
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: Power steering help
Logan,
The n/a power steering lines will work fine. I'm using them on my car and it has the turbo motor in it. The only main difference is that the turbo lines have a heat shield thing over it. I didn't bother putting one on because my exhaust piping is ceramic coated.
