Misfire!
nicklmort
Misfire!
Post by nicklmort »
Intercooler blew off a couple times a few nights ago. And the car has had a sligth miss ever since. at wot car will pull hard for a sec then it feels like no power.Does it whether the motor is hot or cold. doesnt matter the cruising speed, throttle %, or anything. seems to have the same miss all the time
Re: Misfire!
Have you checked to verify there are no boost/vacuum leaks?
Does the miss feel like an ignition mis? Does the miss happen all the time, even at cruise or idle?
