help
help
I have 0 compression in number 2 I pulled the head found that my piston isn't moving so my question is can i replace it without splitting the case beings the head is off these engines are crazy to me any help would be awesome just looking for the simplest way to do this
Just a girl loving to her her hands dirty.
91 legacy ss
91 legacy ss
Re: help
If the piston isn't moving then you've probably got a broken rod or a broken crank. It's gonna have to come out and get the case split to find out what's wrong. Then probably off to the machine shop to get it checked and cleaned and put back together.
The easiest and cheapest way to fix it is most likely to find another engine and drop it in.
