Speaker harness plug question!
logan9691
Post by logan9691 »
I need to know which wire is positive and which is negative or if it matters which is which. This is the plug that plugs into the front passenger speaker.
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: Speaker harness plug question!
I'm not sure to tell you the truth since that doesn't match any of the wire colors in this diagram.
http://www.main.experiencetherave.com/s ... iodiag.jpg
What year did that plug come out of?
BSOD2600
Post by BSOD2600 »
Could use an continuity tester to definitely find out which speaker pair it's associated to...
'11 WRX Limited
'94 TW | R.I.P.
magicmike
Post by magicmike »
plug it into the speaker and put a 12 volt battery accross the terminals. Which ever combination makes the speaker "pop" outward is the correct polarity for the color. i.e if it pops out with the batt + on the blue and Batt - on the gray then there ya go.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
You can use a 9 volt battery too.....it may not pop out as much, but should still work.
magicmike
Post by magicmike »
yesh, I should have specified, doesn't need to be excatly 12 volts. I even think a AA batt will do the trick :)
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
