New way to snorkus delete and coffe cup mod.
Thesubielover
Post by Thesubielover »
So today I did the snorkus delete. I wanted to let everyone know that I dids it a way that I havent seen on here yet. When I get the white lower air box off and took out the double black air feed suction piece, I used a dremel or sawzall and chopped it in half and re inserted it into the fender wall. Esentially that piece has a perfect rubber seal that connects into the black air box, so there was no need to use any pvc pieces. I'll get pics up soon of the mod, I think everyone will like it and it is totally free! I'll be returning my home depot pvc fittings tomorrow. Also, I have an idea for the coffee cup mod which I am tackling this weekend, so I'll have photos up of that as well. Let me know if anyone has questions. I bought an intake drill and vaccume line connector set from autozone, a sillicone 2.5 to 3in piece and am going to be getting just a straight piece on 3in pvc from home depot to drill for the vaccume lines.
Re: New way to snorkus delete and coffe cup mod.
I ended up doing something similar to that but cut it off just after it came out into the fenderwell area. I had to change things a little bit when I went to the newer diagonal airbox because it has a larger opening.
Legacy777 wrote:I ended up doing something similar to that but cut it off just after it came out into the fenderwell area. I had to change things a little bit when I went to the newer diagonal airbox because it has a larger opening.
The top and bottom halves mate. You can run a later diagonal top with the stock bottom, if need be.
beatersubi wrote:The top and bottom halves mate. You can run a later diagonal top with the stock bottom, if need be.
Doesn't the stock bottom piece use screws to attach it to the top piece, while the diagonal air box uses clips? I tried to retain the stock bottom piece when I did mine, but it didn't really look like it was going to work.
No, you're correct. I did use the bottom half, now that I think about it. Dimensionally, they're the same though.
I did the same thing, but with then running a hose with the same diameter from the stock pipe to a NACA duct, also with the same inlet diameter.
Thesubielover
where did you run the duct?
evolutionmovement wrote:I did the same thing, but with then running a hose with the same diameter from the stock pipe to a NACA duct, also with the same inlet diameter.
Also interested in seeing this. Do you have any pics or diagrams? I'm a fan of NACA ducts for they're functionality.
The duct into the stock 'water catch' in the fender might work as a sort of 'ram air' effect while keeping water out of the MAF.
