timing belt tensioner pulley. bolt size
Anyone know exact size for timing tensioner pulley bolt? I know its a 10mm with 1.25 pitch. Part broke off in block so I need to know length
Re: timing belt tensioner pulley. bolt size
Did you end up finding this information out? I'm guessing you did since it sounds like you got the car running from your other thread.
I used a 10x50mm but a 10x60 would be the best option, just wasn't able to extract what broke off. It's a 1.25 thread pitch though
Ok, thanks for the info.
Yep, I went through similar although I didn't break a bolt off, instead I buggered up the threads.
At first like an idiot I didn't notice that the bracket part which bolts the tensioner pulley, is a separate piece that is bolted to the engine block. So I spent $55+ on an M10x1.25 heli-coil kit... then after that heli-coil didn't work out so well, I ended up just replacing the bracket piece.
And I'm still going to need another bracket,
and I'll end up trying to sell the heli-coil kit also.
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
