4eat transmission problems?
U_Got_Scoobed
Post by U_Got_Scoobed »
Hi everyone, I had some questions first off my 92 legacy just stopped moving and its making a weird noise and no go. Fluid levels are good and clean, connections are all plugged in and the noise sounds like its coming from the front of the tranny but only happenes when you rev it up. If someone can help me out just had it replaced about a year and a half ago no warranty:eek:
icrman
Re: 4eat transmission problems?
Post by icrman »
The very first thing to do is check to make sure the torque converter is still attached to the flex plate, that is look and see if the bolts are there. Next thing to do is a pressure check, to make sure the pump is working.
U_Got_Scoobed
Ok so whats bolts am I looking for and how do I pressure check?
Welcome to the BBS.
There is an access hole on the back of the bell housing. There is a plug in it, you can remove it and check to see that the torque converter and flex plate are still connected.
http://www.main.experiencetherave.com/s ... P_2486.JPG
http://www.main.experiencetherave.com/s ... P_2487.JPG
http://www.main.experiencetherave.com/s ... P_2488.JPG
U_Got_Scoobed
Awesome thank you ill try that later and let you know
U_Got_Scoobed
Ok so everything looks ok I guess nothing feels lose, any other insight?
Alphius
Post by Alphius »
Check to see if the front CV axles or rear driveshaft spin when you give it gas. Sometimes a hub will strip or an axle will break and could theoretically cause this problem.
U_Got_Scoobed
Checked the cv axles up front nothing moves same with the rear, the trans got rebuild a year ago but it still the stock torque converter i hope its something easy but its not looking that way I guess
