lowering springs for wagons
so are some of the lowering springs they show online  so far all say for sedans. will they still work on the wagons? i want to do a mild drop next spring
				Thesubielover
Re: lowering springs for wagons
I havent seen any online for the wagons.  Did some research and called h&r.  Call there customer service number and ask for ryan.  See what he says.  I have a sedan, you may need to go with wrx components.
hope they have something that works. or  i could bite the bullet and  get coil overs
i found these   but  not sure if my ride has the right code that they show
http://www.yourhotcar.com/prod/Intrax/S ... 06/557904/
				Thesubielover
seem like these could fit.  i think you should call this website, or maybe both just to verify.  it will save you the hassle.
true  true
The springs for the sedan should physically fit as long as they're for the correct application.  Since the wagon is a little heavier in the rear, you might get a saggy rear end with sedan springs, but more than likely, they'll be fine.
what does  the j6 code mean?
				topsecret888
Those springs u looked at should fit fine. I believe J code meant that it's the BJ code that's for the first gen legacy wagons. Besides, those intrax springs also specifically made for 91 and up legacy wagons, so u should be good to go.turbo970 wrote:what does the j6 code mean?
				WagonMafia
Tein S Techs on s/r kyb gr2s 02-04 wrx wagon springs, 2" drop all around, on 17s looks nice, rides great.
							WagonMafia
-Pure White 93 L Wagon converted to Turbo Wagon (almost complete)
-Pure White 92 SS parts car (doner) donated to friend
-91 Mazda miata drifto DD
http://photobucket.com/wagonmafia
				Thesubielover
Nice input, I was thinking 16's with a 2in drop, but 17's clear and do you have wheel spacers?
				Someperson
I'm looking for about a1" drop on 16s and AGXs, any ideas?
93 Winestone TW project
				WagonMafia
No spacers, I'm not pos of the offset on the wheels, but they're 17x7 with a 205/50-17
							WagonMafia
				robertpaige
Just grab some GC Raceland coilovers. They ride great and look awesome.
when i get my subie back i may try those raceland coil overs. my folks talked to the trans mech. and he said he should be done in a week or 2
				WagonMafia
I have a customer with the racelands on his o/b limited, looks tiiiiight.
							WagonMafia
i wont get a harsh ride with those will i?
				WagonMafia
Never had coilovers on any of my rides before, I couldnt tell you. I can imagine it won't be as plush as stock, but that's to be expected.
							WagonMafia
well i'm hopen to get the car back  in a couple weeks
i run Racelands and actually like them over the cusco coils i had. Race lands are cheep but thes have a good spring rates and are comfy in my wagon.
							90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
				WagonMafia
How cheap?
							WagonMafia
less then 500 new cheap. i really do like them and they can last you a while if you take care of them.
Yes i know my headlight and hood is messed up. got in a fender bender not to long before i took this pic. but this is how low i have my race lands and dont rub. fenders rolled not pulled though. and i have cusco camber plates front and rear. race land does offer camber plates as well.
do the gc's bolt right on with out any mods?
yep. fit right in to our cars
