Pedal Covers
originalcyn
Pedal Covers
Post by originalcyn »
Has any one tried swapping out the pedals from a wrx on to a 1st gen legacy? Not the whole pedal box, just the pedal "covers" i guess?
WRX pedals 36024FA010 - Pad Sport
WRX pedal 36024FA000 - Pad CP - Accel Sports.
This shows how how to do it on a 2.5rs, but i was curious if it was feasible on a 1st gen legacy with an automatic transmission.
http://www.scoobymods.com/showthread.ph ... 5218&t=128
Kijan
1993 Legacy LS | PBM 227
Someperson
Re: Pedal Covers
Post by Someperson »
Could you just install new pedal "arms" if you will?
93 Winestone TW project
Re: Pedal Covers
Yes, you can swap the pedal covers the same way on the 1st gen Legacy.
originalcyn
Re: Pedal Covers
Ooo. Thanks Josh. I might have a new unnecessary project.
I feel like I should just make "Thanks Josh!" my signature.
Kijan
Re: Pedal Covers
You're welcome :)
But you should be thanking Andrew. I just read A LOT of posts, and pick up on all the knowledge others have gained as well.
http://bbs.legacycentral.org/viewtopic. ... 60#p391360
originalcyn
Re: Pedal Covers
Oh nice! I went looking but I didn't pull anything up. Apparently I didn't look hard enough. Sorry for the hassle on that.
Kijan
originalcyn
Re: Pedal Covers
Crap, i just realized the pedal for the brake on automatic trasmissions is rectangular...I'm not certain this is going to work.
Kijan
Re: Pedal Covers
Hrmm?? They make a set for auto also:
https://www.subaru.com/content/download ... atalog.pdf
C8110SA010 (automatic brake and gas pedal set)
originalcyn
Re: Pedal Covers
Mmmm, i wish they didn't have the sti logo on them...i might have to go for that and sell the two pedals i bought, which doesn't really help anyone.
Kijan
oldscoobyturbo
Re: Pedal Covers
Post by oldscoobyturbo »
there is a set for automatics for the wrx too which are the silver tops no logos
I have the pedal covers on my wagon they look nice
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
originalcyn
Re: Pedal Covers
Oh cool! Do you know the part number by chance?
Kijan
oldscoobyturbo
Re: Pedal Covers
i'll take a look and see if I have them
originalcyn
Re: Pedal Covers
Awesome, thanks!
Kijan
originalcyn
Re: Pedal Covers
On the sti pedals, the accelerator pedal fits over the top of the preexisting rubber pedal, which made installation a lot easier. On the brake pedal, the actual pedal is wider than the pedal cover, so there's a little bit of black over hang on either side.
Kijan
Re: Pedal Covers
Thanks for the update!
Any pictures?
Re: Pedal Covers
originalcyn
Re: Pedal Covers
Sorry Josh, i didn't see these posts until today for some reason. I'll try to get some more pictures. As previously mentioned the gas pedal cover fits over the top. On the brake pedal, it's a bolt down. So, at least on the automatics, the rubber cover comes off and the sti pedal cover screws down into the pedal. The proper bolt holes were already part of the pedal.
Kijan
originalcyn
Re: Pedal Covers
Ok, so I took a couple more pictures.
Here you can more clearly see the overhang of the actual brake pedal, as well as the bolts that keep the cover attached.
Here you can see how the sti pedal cover for the gas is really just riding on top of the preexisting rubber pedal cover.
Kijan
Re: Pedal Covers
Ok, thanks for the added pictures.
What floor mats are you using?
originalcyn
Re: Pedal Covers
Legacy Rubber Floor Mats 2005-2009 - J501SAG000
This post should have links to purchase:
http://bbs.legacycentral.org/viewtopic. ... 47#p366847
Kijan
Re: Pedal Covers
Thanks!
I really need mats for my Impreza and they don't make the 1st gen Impreza mats any more.
originalcyn
Re: Pedal Covers
Yeah, my pleasure. The fit pretty well. The driver side could fit better. It has a hole to pin it down, but i'm trying to figure out a way to implement it without cutting holes in my carpet.
Kijan
