Fuel Pump Assembly differences - turbo and n/a
macipusy
Post by macipusy »
What I have gathered from the FSM is that the fuel pump assembly is the same between n/a and turbo models with the pump being the only difference. Can anyone verify this for sure? If I go to the salvage yard and pull a 92-94 n/a fuel pump assembly and swap it into a 93 turbo wagon with a walbro fuel pump, will it work?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Re: Fuel Pump Assembly differences - turbo and n/a
You are correct. The fuel pump assemblies are the same.
