hi eveyrone,
im finally rebuilding my motor as it finally took a crap on me.
im replacing the ej22t with a ej22 n/a short block.
but n e ways im done with one side but the other side the dowel pin is stuck in the cylinder head and i need to get it out to align the HG.
long story short i got a ej22 n/a short block and didnt check if the down pins were in it.
so now i need to remove a dowel pin from another motor to align the HG for the current build.
i've search and all i can find is a how to on a ej25 and those dowel pins are smaller if it takes a 10x1.25 tap.
any help would be awesome so i can finish the build and put the wagon back on the road.
cyliner head to case dowel pin removal
Drive it like you Stole it
Re: cyliner head to case dowel pin removal
Your best bet is to buy new ones. Their part # is 804014060 and are around $2.50 from www.subarugenuineparts.com
A vice grip and slide hammer is good way to remove the old ones, but usually it destroys them when removing them.
Legacy777 wrote:Your best bet is to buy new ones. Their part # is 804014060 and are around $2.50 from http://www.subarugenuineparts.com
thanks, i thought so but wanted to know if there was a way w/o destroying it.
like the ej25 with a 10x1.25 tap.
anyways i've order them from the dealer and will arrive on monday or tuesday.
im also waiting for my auto trans rebuild kit and hope to do a write up on it.
once again.
thanks for the reply.
its just a little sleeve. doesn't screw in or any thing
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
i know its just a sleeve but i was referring to this here.
"tricks of the trade"
http://forums.nasioc.com/forums/showpos ... ostcount=2
No, it doesn't screw in. It's just a compression fit pin.Rubasu wrote:its just a little sleeve. doesn't screw in or any thing
Nice link!
Yeah, that is a pretty cool trick!
