i put the crank sprocket pointed strait up and both cams with the aarows faced up. there are no marks to line up with on the block that i can see. i put the belt back on not knowing there is a timing mark on the belt, the car wont start.. can anyone get the color crayons out and help me time this engine the correct way?
ive looked on a few different sites and found different answers . any help would be appreciated
ej22t ignition timing (newbie)
Re: ej22t ignition timing (newbie)
On the crank sprocket, there are two marks, the arrow, and a notch. You line up the notch with a notch on the crank sensor housing, and the arrow will be pointing at around a 45° angle towards the driver side.
if i remember correct i did set the crank that position, but the cams im not sure if i used the correct aarows and if strait up was the way to go?
Welcome to the BBS.
Check out this post for a picture on where the timing marks are.
http://www.bbs.legacycentral.org/viewto ... 44#p401444
Legacy777 wrote:Welcome to the BBS.
thank you! that answered all my questions perfectly.
