need help!!! right control arm
t2402j
Post by t2402j »
My friend had a 94 legacy, it had a recent acciendent, the fenders gone, endlink got cut in half, and control arms bent.. just recenlty bought a control arm and endlink from a 95 outback.. but now I cant put in on there..
Question??
Did I buy the wrong part??
Is the frame bent too?
Heres the pic of the broken arm
t2402j
Re: need help!!! right control arm
Post by t2402j »
Btw he said if I fix it its mine.
PhyrraM
Post by PhyrraM »
A '95 Outback should use the same control arm, but the rear bushing is different to accommodate the factory 'lift'. It should still bolt in though.
I would look for signs that the crossmember or the rear bushing mounts are out of shape. Maybe the crossmember is out of place?
t2402j
Post by t2402j »
PhyrraM wrote:A '95 Outback should use the same control arm, but the rear bushing is different to accommodate the factory 'lift'. It should still bolt in though.
heres more pics
When you try and bolt up the new control arm, where does it seem like it has issues fitting?
t2402j
Post by t2402j »
Legacy777 wrote:When you try and bolt up the new control arm, where does it seem like it has issues fitting?
The right side hanger.. the one in the last pic.. maybe its twisted?.. how can I fix it?
You mean the front mount on the engine crossmember? How does the other side of the crossmember look, does it look bent? If you mount the front part of the control arm first, how does the rear line up?
PhyrraM
Post by PhyrraM »
I don't recall a big wrinkle like that in the crossmember. I agree....compare it to the other side.
t2402j
Post by t2402j »
still have to check the car is at a parking lot at my work.. if the crossmember is bent.. do i have to replace it?.. can i take that off w/o a lift?
PhyrraM
Post by PhyrraM »
Yes, you can take it off without a lift. Place jackstands in the usual locations, and then place the jack under the motor to hold it up while swapping the crossmembers.
t2402j
Post by t2402j »
finnaly figured it out
thx for the help guys..
So I take it the crossmember was bent?
t2402j
Post by t2402j »
Legacy777 wrote:So I take it the crossmember was bent?
Yup it was off by 1.5 inches..
Got the control arm in.. drove it to my house .. it runs great.. steerings ok, no shaking no pulling.
