installing a wrx ic in my 92 legacy sport
devinshaw3
I was just curious what would be the easiest ic to install in my 92 legacy sport automatic, i can eathier buy a 02 or 03 or 06 one.
Re: installing a wrx ic in my 92 legacy sport
Slanty tmic (92-96 WRX/sti) is the absolute easiest. Works fine out of the box. Second choice would be the 06/07 WRX - you need to buy about $60-100 of silicone and then (gasp) cut it up to fit. Then figure out how you're gonna run a bpv.
Last place would be the 02-05 since it requires you to bash the firewall in. Some people report being able to fit the 02-05 on a stock 22t with only cutting down the throttle body. You still need the silicone tubes, and to figure out how you want to run the bpv.
Check the "sticky" at the top of this forum for more info.
