Fuel Line Size?
CAV3MAN227
Fuel Line Size?
Post by CAV3MAN227 »
-This might be a stupid question, as I have replaced these fuel lines in the past but, What are the sizes of the two fuel lines from the fuel filter to the manifold lines and the return line?
-Joe
robertpaige
Re: Fuel Line Size?
Post by robertpaige »
According to vrg3;
"The fuel hoses are 7.5mm, I believe. I have 5/16" fuel hose on my car. If you replace it be sure to use fuel injection hose and not just regular fuel hose; you need something designed to handle high pressure."
CAV3MAN227
Re: Fuel Line Size?
-Thanks for your quick reply. Sounds like where I messed up, getting the regular fuel line. Its starting to swell and wont stop leaking no matter how much I tighten it.
-Also the smaller line, which I think is the evap line, what size is that one?
-Joe
CAV3MAN227
Re: Fuel Line Size?
-Well the 5/16" hose worked perfect. No more leaks. That smaller, evap hose I will just have to do later.
-Joe
