need correct vacuum routing for boost sol. please
Nate S
Post by Nate S »
ok, so I have dug and dug and cant find it,
is it ,
wastegate on the top side
pressure side of the turbo on the bottom side
then the intake line on teh bottom? or is this swapped?
thanks,
nate
S-Squared Motorsports
Looking for aftermarket parts? Email me
nate@ss-ms.com - www.ss-ms.com
shop # 916 631 7440
92 turbo wagon / 02 wrx sedan
morgie
Post by morgie »
according to that picture i took while unpluging everything ...
all up goes up, all low goes low :)
up side of solenoid goes to the connector on the compressor , down side of the solenoid goes to the wastegate.
morgie
'98 4Runner V6 Manual 4x4.
Nate S
Post by Nate S »
thanks!!!
shop # 916 631 7440
mile hi
Post by mile hi »
The best diagram on the turbo hoses that I have seen came from the computer at the dealer parts counter. If you give me your e-mail I will send you a copy in .pdf format.
AL(CO)
al@iwtu.net
Nate S
Post by Nate S »
emailed ya
shop # 916 631 7440
