fuel injection module ?
turbo970
Post by turbo970 »
well i stopped by the shop and they had dash torn out. they said there's two points on the ecu harness that are empty. they said one of the empty ports is supposed to go to a fuel injection module which is supposed to be under the dash. so my question is is there a module and if there is what does it look like
turbo970
Re: fuel injection module ?
Post by turbo970 »
ttt
We chatted about this on the phone, but here is the ECU I/O. If there's not a number in Vikash's ECU pin out, there shouldn't be a wire going to it.
http://www.surrealmirage.com/vrg3/ecupins/
Additionally, here is an Excel file with the same info that I verified.....it's got the same pins without wires.
http://www.main.experiencetherave.com/s ... CU_I-O.xls
turbo970
Post by turbo970 »
i'll print this info out and give it to the shop owner.i wonder where he got his diagram
Also, if he or you can get a picture of what he's talking about, that would be helpful.
turbo970
Post by turbo970 »
i'll try and get a pic
