I am no new to Subarus. I had a brand new 2004 STI which I traded for a 2010 Legacy GT which is my daily driver. I am in the process of collecting parts for a proyect VW bug that will be using Subaru drivetrain. I will be using an EJ22t wich I already have a NOS shortblock. The DOHC heads won't fit without butchering the back of the car. The SOHC heads of the EJ22t fits on the Bug engine like a glove, so the DOHC are out of the equation. We want to get around 300hp out of these engine. The car will be a 2,000lbs semi daily driver and the engine mated to a reversed 5 speed STI trans. Will like to get your recomendations on this application?
From what I had read here it seems that the OEM ej22t crank with a set of Eagle rods would be fine for my hp goals.
Also read the Wiseco pistons would be a nice set. As this is a totally NOS shortblock(it is even on the original crate) I think I need a set of ej22t stock size Wisecos. Are they available or need to custom order?
As I am set on the ej22t heads I learned here that my best bet would be to send them to Delta cams. I had 2 seats of the ej22t heads: a non rebuild used set and a rebuild set. The second set was bought at RS25 a couple years ago. They were mild ported and coverted to solid lifters. I think that would be the right ones for sending to Delta. What you think?
We can build a custom header. What tube diameter you think?
Being on the VW scene for decades we are very familiar with ITBs, so we want to use TWM ITBs. Not sure on the size yet.
As I am looking for reliable street driving I think a turbo like the GT28x would be good. Need to read a lot on this. I have a couple of turbo books, so it time to look for them.
In my area the Micro Tech and the Haltechs are the most used although the Electromotive,EMS,MS and SDS are also used. Any experience on them?
Injectors recomendations?
Remember this will go to a light 2,000 pounds car with only RWD, so even it get only 250hp at the wheels that would be magic!!!
Thanks for your time and recomendations, if you any links for these please let me know.
Here is a link for my aircooled 1303:
http://www.germanlook.net/forums/showthread.php?t=10985
