2.5rs fuel pump in 92 SS
dillonr92
Post by dillonr92 »
will a 2000 2.5 rs 255 fuel pump work in my 92 SS?
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
wtdash
Re: 2.5rs fuel pump in 92 SS
Post by wtdash »
I wouldn't...that pump may not flow enough. Injectors on the 2.5 are probably <300cc, and yours (if stock) are 360cc.
Physically, it'll probably work but may require an install kit.
EDIT: Missed the '255'...should work.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
dillonr92
Post by dillonr92 »
its a 255 walboro. stock FP was upgraded to this in the RS... i talked to a guy a PRE he said everything from 1992 to 2002. weather it was a impreza or legacy everyting is the same. not to sure but well find out.
dillonr92 wrote:i talked to a guy a PRE he said everything from 1992 to 2002. weather it was a impreza or legacy everyting is the same.
The above statement is not true.
However, the walbro 255 should work fine in your turbo legacy. Depending or not if the electical connector adapter is there, you may need that.
