v3 sti yellow injectors.
Pythonmsh
Post by Pythonmsh »
I was looking into buying a set of these injectors. I was wondering if they'd fit my stock ej22t.
Thanks.
James614
Re: v3 sti yellow injectors.
Post by James614 »
They will fit, but you would need an engine management solution to use them, but a Rob Tune doesn't support them which means $$$$. I would suggest getting v1-v4 wrx grey injectors or 04 STI/EJ255 yellow injectors (the latter requiring a nonturbo fuel rail).
Welcome to the BBS.
Any injector upgrade will require some form of engine management upgrade to support the larger injectors
