engine gets very heavy
ugaucin
Post by ugaucin »
My engine gets very heavy when I try to step on it. If I press the pedal more then half way from a stop, it becomes very heavy and the revs go up very slowly. Anyone else have this problem?
Uriel
1994 N/A Sedan-Daily driver
1994 Touring Wagon 4EAT-Project car #1
Re: engine gets very heavy
Can you please elaborate what you mean by getting very "heavy". Also, provide model and any other info about the car. Have you checked the ECU for codes?
ugaucin
Post by ugaucin »
Legacy777 wrote:Can you please elaborate what you mean by getting very "heavy". Also, provide model and any other info about the car. Have you checked the ECU for codes?
It bogs out a lot
Uriel
What about the other questions I asked? What model & year and have you checked for codes?
ugaucin
Post by ugaucin »
Legacy777 wrote:What about the other questions I asked? What model & year and have you checked for codes?
1994 legacy L fwd. I got the ecu codes today. They're : code 35 and code 21
Uriel
Post by SILINC3R »
I would recommend clearing the codes, drive the car, and then see what comes back. the coolant temp sensor (code 21) is a likely cause for your problems. It may be telling the ECU an incorrect temperature and the ECU is causing it to deliver more fuel, which could cause it to bog.
ugaucin
Post by ugaucin »
Legacy777 wrote:I would recommend clearing the codes, drive the car, and then see what comes back. the coolant temp sensor (code 21) is a likely cause for your problems. It may be telling the ECU an incorrect temperature and the ECU is causing it to deliver more fuel, which could cause it to bog.
Its actually code 22. I put on A new knock sensor and the code is gone. But on my touring wagon has the 21 code. It bogs out pretty bad and its not giving me any HP. Replaced the knock sensor on the wagon also
Uriel
So which is it, code 21 or 22? If you are getting code 21 replace the coolant temp sensor, if you are getting code 22 replace the knock sensor.
ugaucin
Post by ugaucin »
It was the knock sensor. I replace it, my legacy is running much better now. Thanks for the help.
Uriel
Ok, good to hear.
