TMIC and the Factory Scoop
Front, Top, Air, Water.
Benderama
Post by Benderama »
Alright I am going to be adding a TMIC really soon and would like your opinions on keeping the factory scoop. I will be wrapping my headers and up pipe with heat tape and eventually putting my turbo in a blanket. So what do you guys think? I have pulled the shroud and chimney and I will be using a 2007 WRX scoop.
1994 Legacy SS 4.11 4EAT (Other mods planned)
De-Snorkled and K&N Air Filter
2013 Honda CR-Z 6 Speed Hyrbid
Re: TMIC and the Factory Scoop
Post by SILINC3R »
You can use the factory one but yes the 2007 would serve better than the stock
wtdash
Post by wtdash »
IMHO, As important as a bigger scoop is the ducting to get air TO the TMIC. Look @ the splitters used on those that come w/the TMIC's, e.g. WRX, STi, Forester/OB XT, GT.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Benderama
Post by Benderama »
Does the splitter on the 2007 bolt on to our scoop? Or is it at least modify-able to get it to fit on our cars? If not is there a common solution to this issue?
wtdash
Post by wtdash »
Benderama wrote:Does the splitter on the 2007 bolt on to our scoop?
Not that I know of
Not sure.
Here's one option:
You'll need to Search on here and elsewhere for other ideas...I'm working on one, too. But may be a few weeks b4 it's ready to show.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
