TCU code 14 Shift solenoid 2
turbo970
Post by turbo970 »
if this is faulty would it cause random limp modes? i can drive the car a few days and then while driving it goes to limp mode. i pull over put it in park turn the car off then on and it drives fine til it happens again. only code in the tcu is 14. i'm hoping its under warranty do to they are supposed to be new since i had the trans rebuilt.
Re: TCU code 14 Shift solenoid 2
I would maybe suspect there's a loose wire that may be causing that code to come up. If it's a new trans I'd definitely go back and push them for warranty work.
turbo970
Post by turbo970 »
its goin wed the shop that put it in want to do a 3000 mile check up on it. i told him what its doing and he thought the same think
