Any Write-Ups on Installing 4EAT Filter Kit?
Ive been interested in installing a filter kit since I need to change the fluid anyways. Has anyone done this? Good experience or bad?
This is one of the kits I see for sale: http://www.rockauto.com/catalog/moreinf ... cc=1269558
All help is appreciated (even if its a harsh warning lol)
1992 Legacy LS EJ22 N/A
4EAT (in want of a 5MT)
Re: Any Write-Ups on Installing 4EAT Filter Kit?
If you do consider buying go with the kit design for our models. It comes with the mounting hardware, hoses and filter for under $20. Josh's link below has the part number and photo.
http://www.surrealmirage.com/subaru/trans.html
				MikeyMeyagi
its super easy. drain/remove pan, unbolt all bolts holding the filter in, unbolt crossover pipe in front of filter to allow filter to be removed. install new filter with o ring, install crossover pipe, tighten bolts, install pan and fill with 4qts atf. takes about 20 minutes.
i recently did my girls filter on her TW cause it got so clogged with clutch silt the trans stopped working lol
*sold*
*sold*
Hi,
Just to clarify, Mike is speaking of the internal screen/filter - which is also a good idea if the car has some miles on it. (I do NOT recommend ever doing a chemical/power flush on an older Subie trans....I lost Reverse on mine!)
The filter kit URAnooBUS is asking about is external only and installs along the frame rails next to the driver's side cylinder head.
I'd also get the kit from Subaru...it's cheaper to get the entire kit - includes plenty of transmission line hose - than just the filter.
GL,
TD
GL,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Thank you for the instructions. I want to do that as well, I got 216k on my legacyMikeyMeyagi wrote:its super easy. drain/remove pan, unbolt all bolts holding the filter in, unbolt crossover pipe in front of filter to allow filter to be removed. install new filter with o ring, install crossover pipe, tighten bolts, install pan and fill with 4qts atf. takes about 20 minutes.
wtdash wrote:Hi,
GL,
TD
Thanks a ton, thats what i was looking for. I will take a look at Subarus kit. Trying to extend the life on my tranny. If it ever goes out, i wann swat to a 5mt. But thats $$$ i dont have haha
Thanks man for the link, came in handy. Im gonna check today to see if someone already installed one. (i doubt it tho. previous owners did not care about the car)SiCkSTi04 wrote:If you do consider buying go with the kit design for our models. It comes with the mounting hardware, hoses and filter for under $20. Josh's link below has the part number and photo.
You should also install an aux. trans cooler..it'll do more than anything to keep your tranny alive...heat is the killer.
Edit:...ESPECIALLY in FL! (except for this winter! BRRR!)
TD
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
haha yea its crazy down here. bipolar weather...wtdash wrote:You should also install an aux. trans cooler..it'll do more than anything to keep your tranny alive...heat is the killer.
TD
Where would i get an aux cooler kit? any good writeups on installation?
Google found this: http://subaru.rockhopjohn.com/Transcool.pdf
I think B&M makes a good kit...can't find the link ATM.
Like THIS would work for <$60.
Td
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
No experience about the filter. Bad experience with complete fluid exchange. You can't get all the fluid out in most automatic transmission, so to replace most of it, you have to do a running exchange (pulling new fluid at fluid suction line until the return fluid runs clear) or drain and fill 3 times.URAnooBUS wrote:Ive been interested in installing a filter kit since I need to change the fluid anyways. Has anyone done this? Good experience or bad?
If I was getting 50% out with each drain, that got me to almost 90% new fluid. The fluid was correct but my tranny started slipping like hell. I thought I FUBAR'd it. I added Lucas Slip stop additive and it saved my ass, but I'm not doing it again.
It's well established that replacing very old ATF often leads to trouble. I wager that old fluid is already saturated (dissolved as much as it can old) and won't dissolve further stuff whereas new fluid starts dissolving crud, swelling clutch bands and such.
