antenna replacement
pooh
antenna replacement
Post by pooh »
What would be the coolest replacement for a stock antenna for a 93 sedan, a shark fin or a carbon 5 in post or something else? Any ideas greatly accepted
Re: antenna replacement
Anything you do, you would likely have to drill a hole in the roof, which I don't know if I'd suggest just for looks.
I usually just run my antenna lower with a few inches sticking out vs. it out all the way. It looks much better. Here's a pic where you can see the antenna just barely up.
http://www.main.experiencetherave.com/s ... G_5396.JPG
92ColoradoTurbo
Post by 92ColoradoTurbo »
I saw a Perrin antenna once that was black 4in stub that looked as if it would mate up to the stock location. The guy on the forum was asking $40 for a while but said they retail $80. I thought it would look good matching the stock black trim.
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
I completely got rid of my antenna and hole. Tack welded a piece of sheet metal under it and filled it with bondo. I got a cheap electric ampered antenna and mounted it in my rear windshield. Paid 10 bucks or so on ebay.
Sent from my SGH-T889 using Tapatalk
pooh
Post by pooh »
I was thinking of a 5 in. carbon antenna as they just screw onto the stock antenna base. That way no drilling or removing of any stock parts other the metal antenna post, which I will keep on hand.
jefferson
Post by jefferson »
I am with cj only I haven't done it yet. I want to get rid of all the extraneous stuff on the outside.
Jeff
pooh
Post by pooh »
Thanks for all the suggestions guys...I am still considering all options, but really don't want the "old fashioned" antenna
Someperson
Post by Someperson »
93 Winestone TW project
That's basically what I ordered from ebay.
pooh
Post by pooh »
Kinda hard to listen to the stereo if I shave it off ...lol. CJ. when you get you antenna from ebay, let me know how it works for you because I really like the looks of it...thanks again
It's already installed. that project was finished, I think, half a year ago or more. The antenna works well, not perfect, but good enough to get radio. Sometimes it can be static sounding but I am not too worried about that, there are other stations. I may have some photos in my build journal.
