1. Leaks - Front black plastic case gasket, valve cover gaskets, possibly the head gaskets, oil pan gasket, all leak. Is there a good rebuild kit? (I want to autocross)
2. I busted my radiator when I took it out to clean today
3. The belt on the crank closest to the black front covers drags slightly on the plastic cover. I ca push the plastic in a little and it won't touch. What shall I do about this?
4. I will do a compression test and need to know the prep protocol. I read that one should, 1) unplug the fuel pump relay, 2) disengage ignition coils. Where is the fuel pump relay and how do I disengage the coils?
Please advise.
