HVAC clicking noise
dankberries
HVAC clicking noise
Post by dankberries »
Some clicking noises going on when turning the HVAC off and on.
Video: http://youtu.be/uNEcMPCar0k
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Re: HVAC clicking noise
Look in the driver's foot well area up at the heater box. There will be white levers on the side of the box. See if they're trying to move when you hear the clicking.
robertpaige
Post by robertpaige »
I get the same noise when I put my defrost on, yet the def/heat doesn't make the noise.
macipusy
Post by macipusy »
Same here on the defrost thing...not on def/heat either.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
It's quite annoying huh? mine does it when ever i turn defrost off, I cant remember if it does it with def/heat.
robertpaige
Just one of those first gen things I guess.
dankberries
Legacy777 wrote:Look in the driver's foot well area up at the heater box. There will be white levers on the side of the box. See if they're trying to move when you hear the clicking.
This symptom very rarely occurs , but the next time it does I will take a look.
90 Nissan 240sx 2jz
91Beater
Post by 91Beater »
Definitely sounds like motorized dampers trying to pull it past a resistance and skipping gears.
Pull the center vents off and stick a small flash light and a small webcam or an inspection camera down it. You'll be able to see some parts of dampers moving.
Maybe something lodged in there or heater core was previously serviced and reassembled incorrect.
humphreys1588
Post by humphreys1588 »
Mine does this as well, but only when I turn it off. If you turn the heater off and push one of the other defrosts halfway(but make sure it doesn't turn on), the noise should go away…
Brisky
Post by Brisky »
humphreys1588 wrote:Mine does this as well, but only when I turn it off. If you turn the heater off and push one of the other defrosts halfway(but make sure it doesn't turn on), the noise should go away…
This!!!!
That happens to mine as well.
Kind of annoying, but since nothing has stopped working I just accept it as a quirk of my old car....
Brian
2001 Legacy GT - Sedan - White - Manual
18inch TSW Wheels, Federal SS-595 Tires, Centriic Rotors, Stoptech Brake Pads, STi Exhaust, & Torque Solutions Shifter bushings
