Anyone have a spare bad IAC IACV lying around?
91Beater
Post by 91Beater »
It would be grateful if you can really rip it apart and share some photos. I'd like to know what/if any rubber components are present before I use any cleaner on it.
Re: Anyone have a spare bad IAC IACV lying around?
There really isn't any rubber components in there. The only rubber piece is the little check valve on the turbo models (which is separate from the IAC valve).
Here are some pics of the IAC valve
http://www.main.experiencetherave.com/s ... /iacvalve/
Pic of the check valve that gets installed between the IAC valve and intake manifold.
http://www.main.experiencetherave.com/s ... P_5107.JPG
dankberries
Post by dankberries »
I believe their is also a rubber o ring that goes between the head and body
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
dankberries wrote:I believe their is also a rubber o ring that goes between the head and body
Yes there is. You can see it in this picture.
http://www.main.experiencetherave.com/s ... P_6310.JPG
