no spark
croc4000
no spark
Post by croc4000 »
Hi to all im new to the forum and i need help getting my car started it's a ej18 carberator and im not getting spark from the bottle coil ,the coil is new the rotor and ignither are new as well but when i turn the ignition im not getting spark i suspect there is no signal going to the coil telling it to fire but how do i fix it i need some help asap THANKS .
robertpaige
Re: no spark
Post by robertpaige »
What kind of car is this??
croc4000
Re: no spark
Post by croc4000 »
1992 legacy gl im getting power on both wires going to the distributor when ignition is turned on ,is that the correct fountion of the wres .
rallyak
Re: no spark
Post by rallyak »
Dose the car have points or electronic pick up coil? I'm assuming it has electronic ignition, therefore it should have a control module that is the brain box that controls the spark. I would look in to that, but I'm guessing.
I'm also assuming that your over seas, because in the US not many legacy's here had the 1.8L engine.
Charles
robertpaige
Re: no spark
He said it's a GL
rallyak
Re: no spark
Post by rallyak »
Legacy GL models were in Europe & Australia.
Charles
croc4000
Re: no spark
Post by croc4000 »
It has an electric bottle coil the old school type im in barbados
rallyak
Re: no spark
Post by rallyak »
Yes, I understand your coil has one wire going to the cap.
The two wires coming out of the distributor should connect to pick up coil inside the distributor that gives a signal. If you unplug the two wires that your getting power and put an ohm meter on it and spin the engine to see if your getting a signal. If so the pickup coil is good, I believe there should be a control module taking that signal and going back to your coil.
But if you have points in side your distributor then you should have one wire coming out of your distributor and that would go to the - neg side if the coil.
Charles
Re: no spark
Welcome to the BBS.
You can download the Subaru factory service manual. It's for the overseas 92 Legacy and section 2 is the engine section. That section has information on the carbureted engines. Also, section 6 is the electrical and has information on the distributor and coil.
http://www.main.experiencetherave.com/s ... FSM_-_FULL
Like Charles suggested, I would verify that the pick up is working and telling the coil to fire.
croc4000
Re: no spark
Post by croc4000 »
thanks for the help guys got it sorted ,the wiring to the distributor was on the wrong way it seems like it was tampered with before changed it around and she fired right up .
Re: no spark
Glad to hear you got it sorted out.
