What all do I need to swap as far as electrical. I'm not going to use the boost solenoid and it will stay auto for the rest of the year.
I am swapping the whole front crossmember with motor tranny front suspension. I also am swapping the driveline and rear diff.
94 tw swap into a 91 ls wagon
Re: 94 tw swap into a 91 ls wagon
You will want to swap the front harness and the firewall harness along with the ecu. You will need the boost solenoid and the other associated turbo sensors on the passenger strut tower or the car will not boost.
subaru_styles
might as well just swap everything, black interior is much better
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
1994 turbo wagon
You would also need to swap the bulkhead harness since the 91 is not going to have the additional turbo sensors. My recommendation would be to just pull the turbo specific sensor wiring from the TW and add it to the 91 wagon.
The other option is as mentioned, just swap everything....but that's a lot of work.
Its also doable in a day
Sent from my SGH-T889 using Tapatalk
...by a Subaru beast!
So I got the 94 tw today and it's rough. Lol drivetrain is hurtin lots of dents but the electronics and interior are clean. So I am swapping in my 91 ss motor 5 speed and rear diff with its fmic bov exhaust rob tune 550 ecu 550 injectors and all other supporting mods. So the 91 legacy wagon ls will have wiring from the 94 tw and interior. As well as the motor and everything from a 91 ss and front end from the ss. It's gonna be a Frankenstein turbo ls wagon
Here is the car and what I've done to it over the past week.
http://i1291.photobucket.com/albums/b55 ... 90bd74.jpg
http://i1291.photobucket.com/albums/b55 ... e53396.jpg
http://i1291.photobucket.com/albums/b55 ... c13d31.jpg
