Odd wiring
Raquon
Odd wiring
Post by Raquon »
I had to replace my fuel pump this week, checked the relay first and I noticed green wiring that leads from the ecu to the maf. I am completely lost on it
Anyone know what this could be?
Re: Odd wiring
Does this wiring look like something that has been added? Any chance you could take a picture of it?
Raquon
Re: Odd wiring
Post by Raquon »
Legacy777 wrote:Does this wiring look like something that has been added? Any chance you could take a picture of it?
It was added for sure, I will take a picture later today
Raquon
Re: Odd wiring
Post by Raquon »
Sorry for the delay Image
James614
Re: Odd wiring
Post by James614 »
Previous owner possibly found a short/break and re-ran that wire to fix it.
Re: Odd wiring
Is it going into one of the MAF pins and if so, what pin is it going into?
Raquon
Re: Odd wiring
Post by Raquon »
Legacy777 wrote:Is it going into one of the MAF pins and if so, what pin is it going into?
I'm confused I didn't go into a specific pin?
Re: Odd wiring
You may want to peel back the wiring loom and tap to see if it's tapped into one of the wires or is tied into the shielding.
Raquon
Re: Odd wiring
Post by Raquon »
Legacy777 wrote:You may want to peel back the wiring loom and tap to see if it's tapped into one of the wires or is tied into the shielding.
Image looks like it was connected there. Car won't start now haha. Guess I'll solder it back on
Re: Odd wiring
That wire is the MAF's signal wire. The stock wiring must have been messed up and the previous owner wired that new wire in to fix it.
