Soft Brake line clips ?
sleepinsuby
Post by sleepinsuby »
Anyone know the part numbers for the clips that hold the soft brake lines to the struts ? Looked everywhere and can't find and my local dealer the parts guys is dumb as rocks.
94SS full cage 2.2 hybrid build with 04 2.5i heads,JIC coilovers,jdm 4pots,vlsd,jdm TD05 16g ,top mount IC,950 injectors,running ms3x em
91ss ej22t 110k,rebuilt heads,new seals,delta220 cams,td04,wrx top mount,wrx flywheel,wrx trans
92L drift project h6 rwd
Re: Soft Brake line clips ?
For future reference, you can look up all the part #'s you want on your own.
http://bbs.legacycentral.org/viewtopic.php?f=12&t=30531
The front clips are 25546GA400.
The rear clips are 627013001.
Post by SILINC3R »
Yep with that you can put any parts guy to shame. I have to do it all the time unfortunately
sleepinsuby
Josh your the man. Bookmarked that and went in to my local subaru dealer and got them on the way and cars getting inspected tomorrow. Thanks again josh
You're welcome!
