I will be buying a 91 legacy 2.2 turbo here soon
just looking to find what works or whats recommended as to exhaust..........
budsy
91 legacy 2.2 turbo exhaust..what works? whats recommended?
Re: 91 legacy 2.2 turbo exhaust..what works? whats recommen
HI Budsy, welcome to the site. CES is the only company I can think of that still makes.an exhaust that fits the SS, but it will probably cost close to what you're paying for the car!
What most people do is grab something from ebay that fits a 2002-2007 WRX or STI and have a welder extend it to fit, as well as moving the hangers. Without spending several grand on engine management, turbos, injectors etc, there's no benefit to getting a massive diameter exhaust either. 2.5"-3" is really the largest you should be thinking about.
Just grab something from eBay for a 2002-2007 Wrx or Sti that's in your budget. Just remember that without engine management and other mods etc, none is going to make much to any more power than the other.
Leave the stock headers alone under 400hp, or you are hurting performance!
Once again, welcome!
Mister Anderson
I'm running a Tomei ELH with up-pipe, Nvidia DP, and a Tomioka catback exhaust. All of this was intended for a 02-07 WRX.
Burrit-G802
Mister Anderson wrote:I'm running a Tomei ELH with up-pipe, Nvidia DP, and a Tomioka catback exhaust. All of this was intended for a 02-07 WRX.
How much modification if any did it require??
turbo wagon
93 legacy wagon 5speed -Ej22t swap
92 SVX
86 vanagon with an SVX swap
01 outback the lactation-station-wagon
92 SVX
I ran sti exhaust, the invidia downpipe is a bit too long, the rest I made fit easily in an evening on jack stands. 3" turbo back, sounds awesome
Mister Anderson
The header fits perfect. The downpipe hanger matches the transmission mounting point. All the other hangers are off, but not by too much. The tubing bends are all in the correct locations. The axle back portion could be 3 inches longer, but I have no issues with the exhaust exit being in 3 inches from the rear of the car.Burrit-G802 wrote:Mister Anderson wrote:I'm running a Tomei ELH with up-pipe, Nvidia DP, and a Tomioka catback exhaust. All of this was intended for a 02-07 WRX.
