hello my legacy93 ej22 engine seems likes its always misfiring theres a check engine light thts coming on and off ,like flash flash,long pause then flash and sometimes it doest come at all,the error is code 49 i got that by plugin the green connector,do you think its the MAF thats no good??
thank in advance
ej22 misfiring
legacy93sey
Re: ej22 misfiring
HI,
Yes, the MAF is likely the issue. If you have the GREEN label JECS or AUTECS MAF they are readily avl. used as they were used on most Subaru models thru '98/'99....but since you're not USA, I can't say for sure.
GL,
TD
Also, This is in the wrong Forum - Mods will move it.
GL,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: ej22 misfiring
Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
legacy93sey
Re: ej22 misfiring
thanks guys i will try wat you said,hopefully it works
