Running rough throwing code 32 and 17
93FrostWhite
Got off work and legacy starts shacking like a v8 it's throw code 32 o2 sensor and 17 injector 4 I pull plug to injector 4 and engine stays the sam, should I replace the injector?
Re: Running rough throwing code 32 and 17
Check that it's getting power first.
93FrostWhite
Its getting power, any other suggestions?
93FrostWhite
It's throw code 15 now also # 2 injector
Then I doubt it's the injector. Check your wiring.
Check the resistance of the injectors. It should be between 11-12 ohms.
These pages from the service manual may help.
http://www.main.experiencetherave.com/s ... iagram.pdf
93FrostWhite
engine decided to lock up for no known reason
Does your oil smell like gas?
