Hi!
I got T-bone last year at slow speed in town , have a caved in side door.
I wanna go to the junk yard to pick a new one, however they tend to have more 93 than 92.....
What years are compatible with a 92 wagon?
Is a sedan door compatible as well with a wagon?
It's rear passenger side.
Legacy wagon 92 door compatibility
Re: Legacy wagon 92 door compatibility
All doors are interchangeable between 90-94, the only deference on the rear is sedans and wagons have different door glass. The doors them self are the same.
Charles
awesome! tx rallyak!
92-94 *should* have the same wiring, but I believe I had to reuse my original door harness when I swapped a 92 door onto my 91. Not a huge deal, and it might only be relevant if you're swapping the driver side front.
good point!tx!
