EJ20g Swap problems
				ShorelineScooby
EJ20g Swap problems
Haven't been on here in a while, but if anyone remembers me, my knowledge doesn't go very far at all.
'92 SS. Fozze Ej20g block, WRX ej20g heads, VF39 (bad seals i think), STI yellow injectors, GC8a Apex'i PowerFC with AVC-R, COP conversion, Catless dp.
Sputters and stumbles when given throttle, but drives sorta, only got a minute away from my house this morning before I turned around and took her home.
basically I don't have time or space to try to do anything on it. Curious if anyone knowledgable and reputable would be able to come by and take a look. I'm at the point of frustration between life and this car, I'm contemplating just selling the damn thing and cutting my losses, but I really don't want to do that.
I have beer, and food, and some money. Located 98155.
Mods- not sure if this is in the right category or not? Apologies if it isn't.
06 Obxt (Clam-jam daily)
92 SS (Forever broken)
92 240sx Vert (Shitbox money-pit drift project)
Re: EJ20g Swap problems
Do you have FC Datalogit or the Power Commander to tune the PowerFC? Hard to say with an aftermarket ECU if the tune is properly set up or if it is a hardware issue.
				ShorelineScooby
I have the commander, but I'm not tuning. Lawrence at intec is a pfc protuner and taking care of that.
				Pntaste4evr99
 - Winestone Cowboy
Have u thought about just getting the 20g Ecu and a robtune? Kinda simplify things a little? I'd help but I just don't know how much help I can give....electronics aren't really my thing
							94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
				ShorelineScooby
If I had a dollar for every time that's been suggested lol. I suppose I'm just stubborn? Granted, the tune isn't perfect and needs some adjustment, but as of this morning the car barely idles and barely moves down the road, so it seems like it's something bigger.
Maybe a bad injector or coil. Listen to see if all the injectors are firing. Also check to see if the coils are firing. You can also just unplug the injectors one at a tie and see if the car remains running or gets worse.
				Pntaste4evr99
 - Winestone Cowboy
Yeah I bet a lot of ppl have suggested the rob tune. If u want I work in kenmore, so not far from shoreline, I can give u a second set of eyes and ears if u want, just can't promise I'll find anything u haven't yet
				ShorelineScooby
Didn't think about that. I'll probably give that a try today.SILINC3R wrote:Maybe a bad injector or coil. Listen to see if all the injectors are firing. Also check to see if the coils are firing. You can also just unplug the injectors one at a tie and see if the car remains running or gets worse.
I actually live in lake forest park so if you're down, I wouldn't say no ha. I won't be home from work til about 4pm.Pntaste4evr99 wrote:Yeah I bet a lot of ppl have suggested the rob tune. If u want I work in kenmore, so not far from shoreline, I can give u a second set of eyes and ears if u want, just can't promise I'll find anything u haven't yet
I could lend you my robtune so you could see if maybe its a tuning issue
				Pntaste4evr99
 - Winestone Cowboy
I work till around 5-6pm and have stuff after work tonight, but tomorrow after work I could, just let me know
Mike I think other people use your Robtune more than you do hahamike-tracy wrote:I could lend you my robtune so you could see if maybe its a tuning issue
				Pntaste4evr99
 - Winestone Cowboy
Mike I think other people use your Robtune more than you do haha[/quote]
That's funny!! Lol
							That's funny!! Lol
Use the diagnostic screen on the commander to make sure all your ECU inputs are working and withing range.
Sounds to me it could be the temp sensor or TPS not reading properly. Especially if it happened "overnight".
