After plenty of research I landed on a USDM LHD 04-07 STI master cylinder, it bolts right up, however the rod that connects to the pedal is too short. I am able to connect it when the pedal is all the way on the floor, but then it won't come back up because the rod seems to be fully extended already.
This is my first experience with any hydraulic clutch components, am I missing something simple?
Could the master cylinder be different LHD vs RHD?
In this photo the clutch pedal is at the top of its throw
