Fuel rails for 550 robtune?
marsh27
Post by marsh27 »
Would it be better to keep the stock 22t rails with the 550s or use the na rails? I read that the na rails are better but just wanted to check
93 fwd beater wagon
93 tw build in progress
Re: Fuel rails for 550 robtune?
It's not a matter of whether they're better or not, it's a matter of what fits. I don't believe the US STi 550 cc/min injectors will fit in the stock turbo legacy fuel rails. They fit the 92-94 non-turbo Legacy fuel rails.
wtdash
Post by wtdash »
+1
The stock ej22t rails only work for '440' grey side feeds.....also a tune Rob provides.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
impostor
Post by impostor »
25d rails also work, and are quite a bit easier to come by around here.
marsh27
Post by marsh27 »
I was able to use the na rails off my parts car. I just was t sure if I needed to use them or not
93 fwd beater wagon
wtdash
Post by wtdash »
impostor wrote:25d rails also work, and are quite a bit easier to come by around here.
Only with the DOHC intake manifold which only fits the dohc heads.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
impostor
Post by impostor »
Hmm, I'm currently running them on my robtune setup without any problems. Stock ej22t longblock and manifold.
wtdash
Post by wtdash »
Hi
not to argue the point too much more but the bolt holes on the rails are on opposite sides-ej22t/e vs ej25d. Not sure how u made them work?
You can see the EJ20G DOHC (same fitment as EJ25D) rails in my post here http://forums.nasioc.com/forums/showthr ... =injectors
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
impostor
Post by impostor »
Next time I see the car I'll try to get part numbers off them. I could be wrong. I just want to get the info out there if there are other options because around my part of the country ej25's are way more common in the salvage yards.
