92 turbo wagon 5mt swap
HotBoxer
Post by HotBoxer »
It's been awhile since I took it apart and I'm getting around to putting it back together. I don't remember where the fuel lines go and what is that third smaller hard line? And where does the coolant come from to feed the turbo? I'm assuming the top line goes to the coolant tank.
HotBoxer
Re: 92 turbo wagon 5mt swap
Post by HotBoxer »
Or doesn't anyone have any pictures of the fuel lines, specifically from the hard lines behind the brake booster to the filter and then to the hard lines under the intake manifold?
The fuel supply from the fuel filter goes to the top hard line. The fuel return is the other larger line. The third smaller line is the fuel evaporation vent line. You can kind of see it in this picture.
https://main.experiencetherave.com/suba ... P_6001.JPG
The coolant feed to the turbo is from the coolant expansion tank. It's this hose line from the expansion tank.
https://main.experiencetherave.com/suba ... P_6008.JPG
You can take a look at pictures from my engine rebuilds/swap
https://main.experiencetherave.com/subaru/images/ej22t
https://main.experiencetherave.com/suba ... _headwork/
