94 TW with a 05 legacy gt 5mt. Oh also 05 wrx sedan lcas. What axles should I run? I was thinking 05 wrx sedan axles?
Which axles
Which axles
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
The.wee.baby.seamus
Re: Which axles
__TT__ wrote:94 TW with a 05 legacy gt 5mt. Oh also 05 wrx sedan lcas. What axles should I run? I was thinking 05 wrx sedan axles?
Icas? Not sure what that is. The 05 legacy trans is a female style receiver for the axle. So are is the 05 wrx. But I do believe both have the tone ring on the axle where the 94 doesn't so you'll have to remove the ring. Other then that it really doesn't matter which axles you run. Unless they are STI axles.
Re: Which axles
Lower control arms
