Canadian Cluster Swap
wtdash
Post by wtdash »
1992 Canada - spec Sport Sedan Automatic.
Here's what 'dscoobydoo' posted a few years back:
I know the clusters did change from 91 to 92.
I also know that the sedan clusters are different than Wagon and that MT is different from auto.
Anyone know if the USDM is PlugnPlay w/the CDM (Canadian DM) models?
Will NON-turbo clusters work?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: Canadian Cluster Swap
The clusters are a little bit like Legos as well. The interior trim part with the actual speedo is different between the AT & MT, but you can swap that around, the flexible printed circuit can be swapped around. The plastic frame/shell should be the same. So to answer your question....I think you can make a cluster to work and match your existing harness wiring. That's what I did with my electronic speedo cluster.
