215/75/15
208ss
215/75/15
Post by 208ss »
Another stupid question. On my 91tleg I have 98 outback wagon struts on it. Do you think I could fit 215/75/15 tires on it with out cutting anything. It looks like I have enough space between the strut spring perch.
1991 subaru legacy sport sedan
Re: 215/75/15
Unless someone has direct experience on that size and setup my best suggestion would be to find the dimensions of your current tire brand/model online and then compare that to the 215/75/15 size and see if you have clearance.
For example, if the 215/75/15 adds 1" to the overall height see if you have 0.5" of vertical clearance between your current tire. Do the same thing with the horizontal clearance.
